The Makita DSP600ZJ Plunge Saw uses two 18V LXT batteries to drive its powerful 36V brushless motor. This combination gives greater power, speed and runtime offering a performance comparable to, if not better than, a corded equivalent.
The unit has a soft start and a dial-in variable speed control. In addition, the saw features Automatic Torque Drive Technology (ADT) Technology, which automatically adjusts cutting speed and torque throughout the cut, for superior performance. A built-in depth stop allows you to make a shallow 2-3mm preliminary cut prior to cutting fully through the workpiece for a cleaner, splinter-free finish.
The DSP600ZJ has a large 56mm cutting capacity at 0, and bevel angle cutting capability of -1 to +48 with positive stops at 22.5and 45. When used with a rail system (available separately), this saw is ideal for use on site or in a workshop for highly accurate, clean cuts in sheet material. Supplied with Makpac 4 case and inlay.
The machine is supplied as body only without batteries or charger. Part of the Makita LXT 18V Family.
Battery Voltage 18 V
Max Depth of Cut @ 45º 40 mm
Max Depth of Cut @ 90º 56 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 165 mm
Sound Power Level LwA [Uncertainty K] 103 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 92 dB(A) [3.0 dB]
Saw Blade Speed 2,500 - 6,300 rpm
Web Attribute Set Cordless Circular Saws
