This thoughtfully designed 190mm saw allows you to cut to a maximum of 66mm. It has a 1,200W high specification and powerful motor. The flat motor housing lets the saw stand upright and stable when changing the blade. The heavy-duty base, cut from aluminium plate, forms a solid base adding to the overall quality. Depth adjustment simplified using a single action lever. The rubber moulded grip greatly increases comfort when in use. The guarding is die-cast aluminium.
This product is manufactured in the UK, at the Makita factory in Telford.
Supplied with general purpose 12tpi TCT saw blade, rip fence, dust extraction nozzle, hex key wrench and MAKPAC (Type 4) connector case and inlay.
Max Depth of Cut @ 45º 46 mm
Max Depth of Cut @ 90º 67 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 190 mm
Sound Power Level LwA [Uncertainty K] 98 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Motor Power 1,200 W
Saw Blade Speed 5,200 rpm
Voltage 230 V
Web Attribute Set Circular Saws
