The Einhell GE-HC 18Li T Power X-Change Cordless Pole Pruner comes with a quality rail and chain from OREGON for optimum cutting performance. With the adjustable carrying strap this cordless pole-mounted pruner can be comfortably carried. An additional holding area provides a secure hold. The chain is automatically lubricated from an oil tank.
It is an efficient tool for the safe and effortless pruning of high branches from ground level where there is no connection to the electric power grid. This tool is equipped with a powerful Lithium Ion interchangeable battery and a 1-hour high-speed battery charger, which together enable long, uninterrupted work sessions. The telescopic handle can be locked at any length from 880mm to 1120mm for exact adjustment to the required working height.
Supplied with 1 x 18V Power-X-Change 3.0Ah Li-ion Battery, Adjustable Carrying Strap and a 18V Charger.
Specification
Cutting Speed: 2.83 m/s.
Cutting Length: 20cm.
Blade Length: 242mm.
Oil Tank Capacity: 20ml.
Length of Telescopic Bar: 880-1,120mm.
Max. Run Time: 30 min.
Charging Time: 1 Hour.
Weight: 6.3kg.
Battery Capacity 3.0 Ah
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 98.5 dB(A) [3.0 dB]
Batteries Included 1
Battery Type Li-ion
Sound Pressure Level LpA [Uncertainty K] 81.5 dB(A) [3.0 dB]
Web Attribute Set Cordless Hedgecutters
EAN Barcode 4006825601329
