The Einhell GE-LC 18Li Power X-Change Cordless Chainsaw is a high-performance sawing tool, it effortlessly cuts through thicker branches and smaller trunks and is also independent of the mains supply. Thanks to the powerful lithium-ion battery, it is capable of long work inputs without interruptions.
The quality sword with chain by OREGON provides an optimum cutting performance. Additionally, the tool has automatic chain lubrication, which is supplied via an oil reservoir with a large filler hole.
Thanks to the ergonomic grip, this saw lies safely in the hand at any time and can be guided precisely through different types of wood. The claw stop of metal and the kickback guard with immediate chain brake provide additional operational safety.
It is a member of the Power X-Change family and is powered by lithium-ion rechargeable batteries with a battery management system for long life.
Supplied with 1 x 3.0Ah battery and Charger
Specification
Bar Length: 25cm.
Chain Speed: 4.3m/s.
Capacity: 23cm.
Oil Tank Capacity: 220ml.
Charging Time: 1 hour.
Weight: 2.97kg.
Battery Capacity 3.0 Ah
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 97 dB(A) [2.9 dB]
Batteries Included 1
Battery Type Li-ion
Sound Pressure Level LpA [Uncertainty K] 89 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 4.7 m/s²
Web Attribute Set Cordless Chainsaws
EAN Barcode 4006825608335
