The Einhell TP-PS 18/165 Li BL PROFESSIONAL is a high‑precision plunge cut saw built for demanding workshop tasks. Whether you’re cutting wood, panels, or plastics, the plunge function lets you start cuts directly within the workpiece for maximum versatility and control.
Powered by an advanced Einhell Brushless Motor, this saw delivers higher power output, longer runtime, and lower maintenance than traditional carbon‑brush motors. By registering online, users benefit from a 10‑year motor warranty, providing long-term peace of mind. Safety features such as soft start, motor brake, and restart protection ensure smooth and secure operation at all times.
Designed to be compact yet robust, the saw includes a high‑quality aluminium table that ensures stable, straight cuts especially when used with the parallel stop. A viewing window and cutting line indicator help with accurate alignment, while the spindle lock allows fast and simple blade changes.
Tool‑free adjustment of both cutting depth and tilt angle makes setup quick and effortless. The included 165 mm carbide blade delivers clean, sharp cuts up to 56 mm at 90° (without guide rail), enabling work close to edges. A swiveling dust extraction port keeps the workspace tidy, and full compatibility with the Einhell guide rail system offers even greater cutting precision.
Soft‑grip surfaces on the main and front handles provide comfortable, fatigue‑free handling, even during extended use. Lightweight construction enhances maneuverability without compromising stability or performance.
As part of the Power X‑Change range, this saw uses advanced lithium‑ion batteries with intelligent battery management to deliver reliable, long‑lasting power across all compatible Einhell tools.
Technical Specifications
No Load Speed: 5,000/min
Maximum Cutting Depth: 56 mm @ 90°, 42 mm @ 45°
Blade Size: 165 mm (20 mm bore)
Bevel Capacity: 57°
Dust Extraction Port Diameter: 36 mm
Weight: 4.23 kg
Power X‑Change PLUS Starter Kit Included
1 × 18V 4.0Ah Power X‑Change Li‑ion Battery
This high‑performance battery includes a 7‑in‑1 ABS Active Battery Management System, a 3‑step LED charge indicator, and continuous microprocessor monitoring of temperature and voltage. A repair mode helps revive deeply discharged batteries, while premium Li‑ion cells ensure minimal self‑discharge. The rubber‑coated housing provides shock protection, and the recessed ergonomic handle ensures easy handling.
1 × 3A Quick Charger
Compact and wall‑mountable, this fast charger reduces downtime thanks to efficient charging technology and intelligent battery monitoring. A refresh mode allows for the recovery of deeply discharged batteries, and a 6‑stage LED display provides clear charging information.
Einhell Aluminium Guide Rail Set (2 × 1,000 mm)
These precision aluminium guide rails support clean, accurate straight or angled cuts. The slide lining ensures smooth motion, while the splinter guard delivers clean cut edges. Non‑slip gripper strips enhance safety and stability during use. The rails are compatible with the Einhell Plunge Saw and Einhell Expert Handheld Circular Saws.
Included:
2 × Guide Rails (1,000 mm each)
2 × Connector Bars
2 × Track Clamps
Battery Capacity 4.0 Ah
Battery Voltage 18 V
Dust Extraction 36 mm Outlet
Max Depth of Cut @ 45º 42 mm
Max Depth of Cut @ 90º 56 mm
Blade Diameter 165 mm
Sound Power Level LwA [Uncertainty K] 107 dB(A) [3.0 dB]
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 99 dB(A) [3.0 dB]
Saw Blade Speed 5,000 rpm
Web Attribute Set Cordless Circular Saws
EAN Barcode 5052511146598
