The Einhell VARRITO Cordless Power X-Change Multi-Tool is a flexible, high-quality helper for extension and renovation jobs. Speed electronics enables the tool to be adjusted to the particular material and application. Designed for safe, ergonomic operation, fitted with a soft grip and an oscillation decoupled battery uptake for reduction of vibration.
The quick-release helps you to change accessories without additional tools. With magnetic tool fixation for getting the tool ready quickly. The 12-pin tool fixation enables flexible positioning of equipment.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Supplied with:
1 x Triangular Grinding/Sanding Plate.
9 x Grinding/Sanding Paper (3 x P60, 3 x P80, 3 x P120).
1 x Scraper.
1 x HCS Plunge-Cut Saw Blade for Wood and Plastic.
1 x BIM Plunge-Cut Saw Blade for Metal.
1 x HSS Segment Saw Blade for Wood, Plastic and Soft Metal.
1 x Diamond Segment Saw Blade for Tile Joints.
Supplied as body only (no battery or charger).
Specifications:
No Load Speed: 22,000 - 40,000/min.
Oscillation Angle: 3.2°.
Sandpaper Size: 90 x 90 x 90mm.
Weight: 1.02kg.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 89 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 78 dB(A) [3.0 dB]
Web Attribute Set Cordless Oscillating Tools
EAN Barcode 4006825618648
