The Delta sanding pad, with its pointed tip, is ideal for sanding into corners. This ability saves time and money by eliminating the need to rework these awkward spots. Weighing only 1.2kg, this sander is comfortable and controllable for single-handed use. Efficient and clean, it is easy to use even for extended periods of time. It is relatively quiet, operates smoothly and has perfect balance. The high speed and small orbit diameter of just 2.0mm leaves an excellent finish. The clip-on light module illuminates your sanding area and makes it easier to recognise unevenness. Thanks to vibration detection, the light module switches on and off automatically, and can be set to full or dimmed light. The electronic speed control ensures the sander maintains its speed under load and transfers all 250W of power directly to the work surface. It features Festool’s reliable CLEANTEC extraction connecting system. Connecting it to a vacuum results in virtually zero sanding dust left on the surface you are sanding or in the air. Alternatively, you can use the durable, reusable long-life chip collection bag supplied with the machine. It comes in a Systainer case along with a PROTECTOR, for smooth sanding adjacent to a vertical surface and a long-life dust bag. Pad size: 100 x 150mm Delta.
No Load Speed 6,000 - 12,000 rpm
Sound Power Level LwA [Uncertainty K] 83 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 72 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 3.5 m/s² [1.5 m/s²]
Motor Power 250 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 201227
Web Attribute Set Delta Sanders
EAN Barcode 4014549255292
