When traction meets planer quality
The Festool HLC 82 cordless planer is the ultimate solution for precision adjustment work, whether you’re on-site or in the workshop. Designed for versatility, it handles chamfering beams, straightening edge transitions on wallboards, creating rebates on doors, and adapting skirting or infill panels with ease. Powered by Festool’s advanced EC-TEC motor, it delivers constant performance even at maximum chip depth, ensuring flawless results every time. Its ergonomic design guarantees comfortable handling, while the spiral blade reduces noise for a quieter working environment.
With a maximum chip removal of 2.5 mm and a rebate depth of 25 mm, the HLC 82 offers speed and flexibility for demanding tasks. Three integrated 90° V grooves make chamfering simple and accurate, while the removable chamfer adaptor ensures perfect results on beams and square timbers. The planer features dual extraction channels and a connector that can be attached on either side, keeping the hose out of your way for uninterrupted workflow. Plus, the quick-acting brake stops the blade in under two seconds for added safety.
The HLC 82 works seamlessly with all Festool 18V battery packs (except Ergopack) and performs best with the 5.0 Ah or 8.0 Ah Li-HighPower packs for maximum runtime. It incorporates advanced features such as Bluetooth® connectivity for extractor communication, AIRSTREAM technology for faster battery cooling, and electronic overload protection for motor safety.
Supplied with: HW 82 SD HLC 82 spiral blade (577999), SYS3 M 237 Systainer³, Hex Key WAF 2,5 and Short Chip Channel.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 96 dB(A)
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 88 dB(A)
Vibration Cutting Wood [Uncertainty K] 3.5 m/s²
Manufacturer Part Number 578000
Web Attribute Set Cordless Planers
EAN Barcode 4014549436721
