The BO4555 fits neatly into the hand with a conveniently positioned switch and a very comfortable grip, it is perfect for finish sanding a whole range of materials. Abrasive can be attached with hook and loop fixings or it has spring steel clips which can firmly secure the abrasive paper.
The through-base extraction uses the punch plate supplied to perforate individual abrasive sheets. The waste is drawn via an integral fan and deposited into a detachable waste bag. If preferred, the waste bag can be removed and replaced by an extractor hose for improved dust extraction.
Supplied complete with dust bag, packet of abrasive paper and paper punch, can be used with abrasives with or without hook and loop backing.
Dust Collection Dust Bag Supplied
No Load Speed 14,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 93 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 80 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Motor Power 200 W
Voltage 230 V
Web Attribute Set Palm Sanders
