The Mirka DEROS II 750 Random Orbit Sander 175mm 230V is a professional-grade orbital sander designed for efficiently sanding larger areas. With its 175mm sanding pad, this sander allows you to complete tasks more quickly and effectively. The powerful 400W brushless motor ensures that even tough sanding jobs are handled with ease, providing consistent speed and more power while requiring less maintenance and offering a longer lifespan.
Comfort and convenience are at the forefront of the DEROS II 750's design. Its ergonomic build ensures comfortable use over extended periods, and the Bluetooth connectivity feature allows you to monitor vibration levels through the myMirka app. Additionally, the variable speed control provides flexibility for different sanding tasks, making this sander a versatile tool for any professional or DIY enthusiast. Compatible with Mirka Dust Extractors, the DEROS II 750 is an excellent addition to your sanding toolkit.
Maximum RPM 9,000 rpm
Sound Pressure Level LpA [Uncertainty K] 71 dB(A)
Vibration Sanding [Uncertainty K] 2.8 m/s²
Motor Power 400 W
Web Attribute Set Random Orbit Sanders
EAN Barcode 6416868201161
