Axminster Woodturning
Axminster Quartz Clock Movements
SKU: 800433
€3,95
  • Quartz-controlled
  • Accurate to within 30 seconds per month
  • 55mm square, 15mm deep body
  • Either 14.5mm or 23.5mm shaft protrusion beyond front face of case
  • Thread lengths 7mm or 16mm
  • Hanger plate provided with each movement
A choice of two quartz-controlled clock movements, accurate to within 30 seconds per month and capable of running for one year on a single AA battery (not supplied). The body is 55mm square and 15mm deep and there is a choice of shaft protrusion beyond the front face of the case of either 14.5mm or 23.5mm. Thread lengths are 7mm or 16mm respectively, your choice dependent on the thickness of the dial being used. A hanger plate is provided with each movement. Please note this is the quartz clock movement only.
Batteries Requires 1 x AA
Difficulty Beginner
Web Attribute Set Project Kits
EAN Barcode 5052511041381
