Penn State Industries
Deluxe Stainless Steel Pizza Cutter Kit
SKU: 110893
€33,00
  • Easy to make project; simply turn between centres
  • Durable, Stainless Steel cutter
  • Removable for easy cleaning
Cut your pizza with style and ease with this useful kitchen utensil. Featuring a durable, Stainless Steel cutter and heavy-duty chrome components, this pizza cutter will not only perform, but will impress too. The 24kt gold plated washers add an elegant touch to your turned handle. A threaded insert allows you to conveniently remove the cutter from the handle making it easy to wash and keep clean. With a 4 Stainless Steel blade and a chrome finish, it's easy to make; simply turn between centres to the length of your choice.
Drill Bit Required 2026-02-01 00:00:00 +0000
Web Attribute Set Project Kits
