Perfume Atomiser Spray Kit
SKU: 503502
€21,00
  • Low cost kit in a choice of finishes
  • Makes an attractive looking project
  • 13mm diameter and 70mm long removable atomiser
  • New and improved design
A great value kit available in a gold finish which, when combined with a well grained timber or acrylic blank, makes up into a very attractive looking project. The atomiser features a new and improved design and measures 18mm diameter by 87mm long and we would recommend a wood blank of around 30mm diameter by 80mm long for turning both the body and the cap. The perfume or aftershave is stored in a small glass vial inside the atomiser to prevent contact with the metal parts. We recommend using material approximately 30mm in diameter by 80mm long to allow for decorative woodturning on the barrel and cap. 15mm drill required. Filling funnel supplied. When using a mandrel to make these kits, bushing set 504486 will be required.
Degree of difficulty 2
N.B. the larger barrel sleeves will be required when using the universal barrel trimmer to hold the 37/64 brass tube from the perfume kit.
Difficulty Intermediate
Drill Bit Required 15 mm
Bushing Set Order No. 504486
Minimum Blank Size 25 mm x 25 mm x 100 mm
Finish Gold
Web Attribute Set Project Kits
EAN Barcode 5052511059300
