Stainless Steel Bottle Stopper
SKU: 106538
€13,00
  • Made in the UK
  • Solid stainless steel body
  • Classy looking wine bottle stopper
  • Perfect way to use up off cuts
  • Unique glue screw simplifies construction
  • Weighty teardrop shape; sits upright
  • Silicone rubber gasket seals bottle
  • Components only, does not include blank/material
N.B. Each kit is supplied as the components only and does not include the material/blank.
Here’s a chance to turn some of those off cuts that are too good to waste into something practical and highly decorative. These classy, british made, solid stainless steel bottle stopper bodies only require you to turn a top piece to transform them into your own uniquely designed wine bottle stopper. The bodies are 66mm long and 25mm diameter at the top. The teardrop shape ensures they sit upright when placed in a bottle.
Pilot Hole - 8mm
Note: The Stopper’s spigot is 8mm diameter x 15mm long and knurled to help ensure a secure fixing. We recommend using CA or epoxy glue for extra security.
To make turning the bottle stopper a little easier, we recommend using the Axminster bottle stopper arbor (code 212316 for 1MT or 212317 for 2MT).
Difficulty Beginner
Made in Britain Yes
Intended Use Components only to make a custom wooden bottle stopper.
Web Attribute Set Project Kits Pilot Diameter: 8 mm
EAN Barcode 5052511119387
