This is a high quality, two speed fretsaw that has several outstanding design features that make it a pleasure to use. The arms are made from magnesium to reduce the moving weight by 40%, ensuring extremely low vibration and quiet running. They run on precision bearings and are very slender to allow a clear view of the work. The table slides back 80mm to make blade changing easier. It also tilts between -5
Proxxon
PROXXON DS 460 2 Speed Scroll Saw
| Dust Extraction Outlet | 43 mm |
| Max Depth of Cut @ 90º | 60 mm |
| Rating | Home/Light Trade |
| Stroke Length | 18 mm |
| Table Size | 400 mm x 250 mm |
| Table Tilt | 5 - 0 - 50 |
| Throat Depth | 460 mm |
| Motor Power | 205 W |
| Web Attribute Set | 230V Scroll Saws |
| EAN Barcode | 4006274270947 |
