IMPORTANT: If you would like more information on this JSP PowerCap® Infinity® respirator before purchase please contact our customer support team on 03332 406406.
The JSP PowerCap Infinity, PAPR (Powered Air-Purifying Respirator) offers high level protection against multiple hazards. It combines TH3 respiratory protection with eye, face and head protection with the option of adding Sonis ear defenders for hearing protection. All this comes in the form of a fully integrated helmet mounted unit, without the inconvenience of waist belts, lengths of tubing or extra cables.
The system uses a powerful, lightweight, battery powered fan to draw air through the filters and then blow clean air down over the user's face. The supplied Li-Ion battery delivers clean filtered air for up to 8 hours on a single battery charge. This positive pressure system allows the user to breathe normally, eliminates misting inside the face shield and accommodates facial hair without any loss in protection. The high capacity HEPA filters coupled with aerodynamically optimised pre-filter covers ensure the PowerCap Infinity can deliver 160 litres of clean air per minute.
Real time diagnostics monitor the system twice a second. During periods of high respiratory demand the system compensates and maintains a positive pressure inside the respirator. The respirator provides accurate, dynamic feedback on battery and filter condition via a heads-up display and audible notifications.
The integrated face shield protects eyes and face from impact, dust and debris while providing a clear wide field of vision. The visor offers impact protection at speeds of up to 270 mph (tested using a 6mm steel ball bearing). The visor has K rated anti-scratch coating and a replaceable peel-off visor protector to prolong its life.
PowerCap Infinity incorporates the high performance JSP EVO5 Olympus industrial safety helmet. One key design element is simple maintenance and cleaning, ensuring the unit delivers the safest and longest possible working life. All parts are easily replaceable, this includes filters, filter covers, visor, peel-off visors, helmet, harness strap, turbo drive unit and carrier, battery pack, visor seal, charging dock, airflow indicator test unit and carry case. Weight: 1.2kgs.
Respiratory protection: TH3, with a Nominal Protection Factor of 500 (UK APF {Assigned Protection Factor} 40), the highest possible rating in the EN 12941:1998 + A2:2008 standard.
Full-face protection: Optical class 1 visor conforms to EN166.B.
Head protection: Conforming to: EN397 (European Standard). ANSI/ISEA Z89.1 (American National Standard). CSA Z94.1 (Canadian Standard). GB2811 (Chinese Standard).
Please note as this is a Health and Safety respiratory item, we cannot accept items for a refund once the packaging seal is broken and item has been worn.
Battery Type Li-ion
Web Attribute Set Respiratory Protection
EAN Barcode 5038428302722
