The heavy duty roller/ball stand combines several outstanding features in one unit. Constructed from a combination of 50mm diameter round and square steel tubes, and has a choice of either 330 long by 60mm diameter roller (ball bearing mounted) or a row of 8 balls, to allow for all-round movement of sheet material. Roller height is adjustable over a range of 735mm to 1,120mm and the telescopic stem locks in position with a very solid knob. A unique wedge lock ensures the roller setting will not vary, making it suitable for heavy baulks of timber. The whole unit folds flat for storage. Maximum capacity 200kg.
Axminster Heavy Duty Roller Ball Stand
| Web Attribute Set | Material Support |
| EAN Barcode | 5052511024568 |
