Turning in miniature is a pleasing hobby. This precision made wood lathe is fitted with electronic speed control. The ball bearing spindle is bored through at 10mm, for series production of small parts. The stable tool rest is adjustable in all directions. Powerful drive motor with speed control between 1,000 and 5,000rpm. Bed is made from stable, thick-walled aluminium profile. A faceplate for turning larger items is included. Workpieces are secured by means of collets (one each of 2, 3, 4, 6, 8 and 10mm) are included. Centre distance of 250mm, 40mm swing, 25mm swing over support.
Proxxon
PROXXON DB 250 Micro Woodturning Lathe - 230V
| Collets Supplied | 2, 3, 4, 6, 8 and 10 mm |
| Power | 100 W |
| Rating | Home/Light Trade |
| Web Attribute Set | Woodturning Lathes |
| EAN Barcode | 4006274270206 |
