The MBS 240/E has a solid, ribbed die-cast aluminium housing and features double ball bearing aluminium pulleys. Its sturdy, machined table with slot for mitre gauge measures a generous 200 x 200mm. The table tilts through 45° for accurate mitre sawing. The machine is powered by a low noise 230 Volt motor (high quality, for quiet, prolonged use) with toothed belt drive. The speed is controlled electronically for exceptionally accurate cutting. A clear table indicates the recommended speed for most materials. The blade size (5.0 x 0.4 mm) is ideal for fine work, allowing cutting of small radii. Standard equipment includes one 1,065 x 5.0 x 0.4 mm (14tpi) band saw blade. A diamond blade is available for cutting glass and ceramics.
Overall L x W x H 510 mm x 432 mm x 330 mm
Rating Home/Light Trade
Table Size 200 mm x 200 mm
Table Tilt 0 - 45
Sound Pressure Level LpA [Uncertainty K] 70 dB(A) [3.0 dB]
Motor Power 80 W
Web Attribute Set Proxxon Power Tools - Bandsaws
EAN Barcode 4006274271722
