PROXXON tools come with a reputation for quality and this small angle polisher is no exception. It uses a quiet, powerful DC motor with continuously variable speed control (full-wave electronics) for low and constant speeds even during high contact pressure. Motor power is transferred to the planetary gearing which is contained in a robust, die-cast aluminium housing. The main body of the machine is made from glass-fibre reinforced POLYAMIDE with a softer section on the underside making it more comfortable to hold. Supplied with a rubber backing disc with hook and loop fastening, polishing sponge (medium hard), lambswool polishing disc, polishing felt for metals and non-ferrous metals (medium hard), 12 sanding discs K 2000 and NIGRIN, polishing emulsion (75ml) as well as a microfibre cloth. The polisher and accessories are stored in a stylish polypropylene case with a handle and two snap closures, ready for immediate use.
Corded or Cordless Corded
Web Attribute Set Proxxon Power Tools - Grinders
EAN Barcode 4006274286603
