The extra gluing area produced by using this cutter makes for an incredibly strong edge to edge joint. With a maximum cutting depth of up to 38mm, most board thicknesses can be accommodated. Recommended for router table use only.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 38 mm (1.1/2")
D = Overall Diameter 35 mm
Web Attribute Set Jointing Router Cutters D: 35 X: 38
EAN Barcode 5052511030682
