Choose from our useful range of keyhole cutters, designed for creating a keyhole type recess and to attach frames and fitments flush to the wall.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 12.7 mm (1/2")
D = Overall Diameter 12.7 mm (1/2")
C = Width of Groove 4.8 mm (3/16) Web Attribute Set: Drawer Pull & Keyhole & Mitre Lock Router Cutters C: 4.8 D: 12.7 E: 6.35 X: 12.7
EAN Barcode 5052511030644
