A great value cutter for a one off job or those times when it may not be a good idea to use your best high quality expensive cutter. This 1/2 TCT router cutter will cut solid wood and laminate kitchen worktops, leaving a clean finish for a close fitting joint, when used with a worktop jig and 1/2 router. Twin flutes ensure smooth and efficient cutting. With a cutting depth of 51mm it is ideal for general worktop cuts.
N.B. The cutter does not have a bottom cut.
Pack Quantity 1
Web Attribute Set Straight Router Cutters
EAN Barcode 5052511123216
