The Reverse T&G Cutter works in a very similar way to a tongue and groove cutter. It is suitable for the accurate jointing of materials to form wider panels for items like table tops. The interlocking profile increases the gluing surface and allows better alignment resulting in a stronger joint that requires less cleaning up.
A very positive way of aligning and providing extra surface gluing area when jointing boards. As with all Axcaliber cutters they are manufactured using the very latest technology. Please note this cutter set is for use in router tables only.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 25.4 mm (1")
D = Overall Diameter 41 mm (1.5/8")
Web Attribute Set Jointing Router Cutters D: 41 X: 25.4
EAN Barcode 5052511030729
