A radius router cutter is probably the second most popular style of cutter after basic straight cutters. They cut simple round bottomed grooves, which makes them very useful for many applications.
Larger diameter examples are good for finger grooves in drawers, grooves in cutting boards etc. When used partially covered by the router fence these cutters will produce coves on an edge. Plunge cutting leaves a round bottomed hole ideal for boards with small recesses for storing marbles.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up. Suitable for hardwood, softwood, plywood and composites.
Shank Diameter 1/2" (12.7 mm)
X = Depth of Cut 22.2 mm (7/8")
D = Overall Diameter 38 mm (1.1/2")
R = Radius 19 mm (3/4")
Flutes 2 Web Attribute Set: Radius, Cove & Cavetto Router Cutters D: 38 R: 19 X: 22.2
EAN Barcode 5052511028917
