These cutters are not bearing guided, they would need to be used with a side fence for hand held use or used inverted in a router table utilising the fence.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 16 mm (5/8")
D = Overall Diameter 19 mm
R = Radius 6.35 mm (1/4")
Web Attribute Set Ovolo & Rounding Over Router Cutters D: 19 R: 6.35 X: 16
EAN Barcode 5052511029143
