Designed for router table use, this matching pair of cutters are excellent for quickly producing a tongue and groove joint in material up to 19mm thick. Each cutter is 47.6mm in diameter with a 22mm bearing which produces a tongue or groove 12.8mm long by 6.35mm wide. (1/2
Axcaliber
Axcaliber Tongue & Groove Set
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 19 mm |
| D = Overall Diameter | 47.5 mm (1.7/8") |
| C = Width of Groove | 6.35 mm (1/4) H = Horizontal Depth of Cut: 12.7 mm (1/2") Web Attribute Set: Jointing Router Cutters C: 6.35 D: 47.5 H: 12.7 X: 19 |
| EAN Barcode | 5052511054077 |
