A deeper profile than the Classic moulding, this profile has many uses in joinery or furniture making. Some very attractive picture frames could also be produced using this cutter.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
Shank Diameter 1/4" (6.35 mm)
X = Depth of Cut 25.4 mm (1")
D = Overall Diameter 22.2 mm (7/8")
R = Radius 2 mm
Web Attribute Set Edge Moulding, Cornice & Handrail Router Cutters D: 22.2 R: 2 X: 25.4
EAN Barcode 5052511030439
