This cutter will produce a traditional classic moulding of the type used on skirting boards and similar applications. Bottom bearing guidance also allows curved work to be carried out.
Axcaliber
Axcaliber Victorian Torus Moulding Cutter
| Shank Diameter | 1/2" (12.7 mm) |
| X = Depth of Cut | 36.5 mm |
| D = Overall Diameter | 31.75 mm (1.1/4") |
| R = Radius | 9.5 mm (3/8") |
| Web Attribute Set | Edge Moulding, Cornice & Handrail Router Cutters D: 31.75 R: 9.5 X: 36.5 |
| EAN Barcode | 5052511030293 |
