This range of Festool spiral cutters in HSS is suitable for many applications. Spiral cutters offer a superior finish with higher possible feed rates due to excellent chip clearance. Twin flutes ground around the body of a spiral bit help eliminate vibration by spreading the cutting action over a longer edge. With their drill-like points, spiral upcut bits are also better for plunge cuts, decreasing the likelihood of burning the work.
Festool
Festool Spiral Upcut Router Cutters
| Manufacturer Part Number | 490945 |
| Shank Diameter | 8 mm |
| X = Depth of Cut | 19 mm |
| D = Overall Diameter | 8 mm (5/16") |
| Web Attribute Set | Spiral Router Cutters D: 8 X: 19 |
| EAN Barcode | 4014549000373 |
