The Kreg Precision Benchtop Router Table delivers the capability and accuracy of a full‑size router table in a compact, portable format. Designed for use in the workshop or on site, it combines a rigid steel base, a stable laminated table top and a full‑featured aluminium fence to provide reliable control for a wide range of routing tasks. Its compact footprint makes it easy to position on a bench while still offering the stability needed for precise work.
The reinforced MDF table top measures 16″ x 24″ and is edge‑banded for durability, with an impact‑resistant Easy‑Slide Micro‑Dot surface that allows workpieces to move smoothly and consistently. A full‑size router insert plate supports even larger routers and includes Level‑Loc reducing rings that twist and lock flush into place for accurate cutter clearance. Unique bottom‑up levelling adjusters make it easy to fine‑tune the insert plate so it sits perfectly flush with the table surface.
The anodised aluminium fence features independent sliding faces for improved workpiece support and accurate cutter positioning. Quarter‑turn locking levers allow fast adjustment while holding the fence securely in place during use. Supplied jointing rods enable the fence to be used for vertical jointing operations, while an integrated dust port and vacuum shroud help keep the working area clean. Built to withstand regular use, the rigid steel stand and vibration‑dampening rubber feet help reduce noise while maintaining stability during routing.
Web Attribute Set Router Tables
