The Kreg Precision Router Table Stop is designed to add accuracy and repeatability when working with the Kreg Precision Router Table or Precision Benchtop Router Table. Its low‑profile anodised aluminium construction allows it to sit neatly on the fence without interfering with material flow, while the flip‑up design lets the stop be moved completely out of the way when it’s not required.
A built‑in Precision Lens Cursor provides a clear, magnified view of the fence scale, making it easier to set and return to exact positions for repeat cuts. Simple to fit and use, the stop is ideal for batch work or any routing task where consistent fence positioning is essential, helping improve both accuracy and efficiency in the workshop.
Web Attribute Set Router Table Accessories
