The UJK Professional Cast Iron Router Table Top is one of a range of options that you can choose from when making up your UJK router table. Simply add the leg stand, fence and required insert and you will have a very sturdy versatile unit capable of many routing operations. The benefits of using cast iron for the manufacture of machine tables are well known especially where vibration damping and stability are paramount. The quality of the surface grinding on this 815 x 615 x 40mm top is superb, offering little resistance when passing stock across the table during use. A standard 19mm wide slot is incorporated for the use of a mitre fence attachment and a T-slot is also present for jigs and accessories. The top is designed to accept the UJK leg stand, fence assembly and optional dust collection box, but it could also be used for making up your own custom-made table. The 306 x 230mm central aperture will accept the router elevator and other available UJK insert options.
UJK
| Web Attribute Set | Router Tables |
| EAN Barcode | 5052511054688 |
