The UJK Variable Speed Motor for Router Lift is a powerful and refined upgrade, purpose-built to maximise the performance of your UJK Router Lift system. Delivering a robust 1,800W output, it provides the consistent power required for demanding routing tasks, while the variable speed range of 10,000–22,000 RPM ensures precise control across a wide variety of cutters and materials.
Designed with workshop practicality in mind, the motor features an easily accessible control box that can be positioned to suit your layout, giving you greater flexibility and convenience during use. A soft-start function enhances safety and control by reducing initial torque, while constant-speed electronics maintain reliable performance under load, helping you achieve clean, accurate cuts every time.
Premium sealed shaft bearings are engineered to minimise bit run-out, improving precision and finish quality. Supplied with both UK and EU plugs for versatility, this motor is the ideal replacement or upgrade solution for users looking to get the very best from their router lift setup.
Please note, this motor requires a UJK Mount for use with the UJK Router Lift, available separately. It is also compatible with other leading router lift systems that use a similar mounting configuration.
Web Attribute Set Router Table Accessories
EAN Barcode 5052511145720
