The GKF 600 palm router from Bosch comes with built-in versatility. It's hugely useful for the trimming laminates, edge moulding, mortising hinges and any other work that benefits from a powerful but light and easy to control router. The 600W motor means that this palm router is almost as powerful as many 1/4 routers and more powerful than many dedicated laminate trimmers. This versatile router, with its neat and compact design (overall size 94 x 94 x 190mm high) is easy to handle and control and is especially suitable for confined areas.
The height adjustment is really easy to set, a lock lever releases the motor from the base allowing quick coarse adjustment; the micro fine adjuster dial can then be used to set height accurately. The base allows a clear view of the cutter so you can see exactly where you are cutting. The spindle lock makes changing cutters easy. Fitted with a 1/4 collet, the 600W motor runs at 33,000rpm.
The GKF 600 comes with a Parallel guide fence, a Bearing guided fence, 1/4 collet and collet nut, 17mm spanner and a storage/carry case.
Collets Supplied 2026-04-01 00:00:00 +0100
Dust Extraction Outlet 40 mm
Overall L x W x H 94 mm x 94 mm x 190 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 4.5 m/s² [1.5 m/s²]
Motor Power 600 W
Plug Fitted UK 3 pin plug
Cutter Speed 33,000 rpm
Web Attribute Set Routers
EAN Barcode 3165140428903
