The MICROJIG MATCHFIT Grid Routing Guide Kit is an innovative routing guide kit designed to create accurate dovetail clamp track grids on panels of virtually any size. Combining a self-indexing guide with a MATCHFIT Dovetail Router Bit and Relief Bit, it eliminates the need for measuring, marking or straight edges. The system creates perfectly spaced 4 x 4 dovetail grids, making it easy to build custom workbenches, sleds, jigs and fixtures with versatile clamping options. Compatible with most routers, this routing grid system helps woodworkers achieve fast, repeatable and professional-quality results.
EAN Barcode 815267012143
