The Bosch S922HF blade is suitable for wood and metal cutting making it a good all purpose blade, the longlife Bi-metal blade is 150mm in length and is suitable for cutting wood up to 100mm, and metal plates, pipes and aluminium profiles up to 3-12mm. A great blade to use if you are working with wood with nails such as pallets.
Blade Type Bi-metal, Milled and Side Set
Tooth Pitch \ tpi 2.54 mm \ 10 tpi
Web Attribute Set Sabre Saws Blades Sabre Saw Blade Cutting Capacity: up to 100 mm Sabre Saw Blade Length: 150 mm
EAN Barcode 3165140093521
