Scan
Scan Moulded Valved Clear Safety Goggles
SKU: 113840
€11,00
  • FFP2 & FFP3 options for fine/ultra-fine particle filtration
  • Tri-fold design: flexible, secure & compact
  • Valve, nose clip & soft seal for comfort
  • Ideal for sanding, cutting, plastering & insulation
  • Single-use; EN149:2001 + A1:2009 compliant
Lightweight yet durable, these goggles provide reliable eye protection against liquid splashes, debris, and high-speed impacts up to 120m/s (270mph). The blue-tinted PVC frame houses a clear, impact-resistant lens, while removable valve caps allow use as either direct or indirect vent goggles.
Features include:
Adjustable elastic headband with ball-joint fittings
Comfortable fit and wide coverage
Conforms to EN 166:1B
Web Attribute Set Eye Protection
EAN Barcode 5023969318950
