Restorer
Restorer Tool Knotted Wire Brush
SKU: 114107
€61,00 €65,00 Save €4,00
  • Creates an extreme, deeply aged texture on wood in seconds
  • Twisted steel wire bristles strip soft grain and cut into hard grain
  • Ideal for dramatic distressing and reclaimed‑wood effects
  • Durable twisted‑wire construction for long‑lasting performance
  • Works best when followed with the 80G Nylon brush (110732)
  • For use with the Restorer tool
Create dramatic, deeply aged texture on timber with the Restorer Twisted Steel Wire Brush. Designed for extreme material removal, this specialist brush uses tightly twisted steel wire bristles to dig aggressively into the surface of the wood. As it cuts, it quickly strips out the soft grain, producing an instantly weathered, rugged appearance. When used across the grain, the twisted coils are powerful enough to tear into the hard grain too, transforming fresh timber into something that looks thousands of years old in a matter of seconds.
Its strength and cutting ability make it ideal for woodworkers seeking an authentic aged or reclaimed look, whether for furniture, creative projects, decorative panels, or dramatic visual effects. To refine the texture once the initial shaping is complete, it performs best when followed by the WRBW80 80 Grit Nylon Brush (SKU 110732), which helps clean up the fibres and enhance the definition created by the steel wires.
The brush is manufactured from twisted steel wire bristles that deliver durability, power and consistent cutting performance. Whether you are distressing new timber, enhancing reclaimed wood, or looking to add character to a project, the Restorer Twisted Steel Wire Brush offers a fast and effective way to achieve a truly unique aged finish.
Web Attribute Set Belt Sanders
