The Hermes RB377YX Abrasive Belts are powerful, semi-flexible aluminium oxide belts with a durable cloth backing. These belts are designed to deliver high performance and versatility, making them an essential tool for professionals in various industries. Whether you are involved in metalworking, tank and vessel construction, or any application requiring precise and efficient grinding, these belts are the perfect choice.
The abrasive belts offer several reasons for professionals to choose them. Firstly, they provide high stock removal rates in the coarse grit range, ensuring that you can quickly and efficiently remove material. This makes them ideal for heavy-duty applications where time and efficiency are critical. Additionally, these belts maintain a very constant surface quality in fine grit sizes, ensuring a smooth and consistent finish on your workpieces.
Moreover, the belts are designed for universal applications. They can be used in both dry and wet conditions, as they are resistant to water, emulsion, and oil. This versatility makes them suitable for a wide range of environments and tasks. Furthermore, these belts exhibit very good running properties, ensuring smooth and reliable operation during use. These abrasive belts are ideal for the Axminster Workshop AW18BDS Workshop Sander.
Sold singly.
Abrasive Belt Width 25 mm
Abrasive Backing Cloth
Abrasive Grit 60
EAN Barcode 4045191364063
