Tough, hook and loop backed abrasive sheets for the Festool RTS 400 palm sander and other sanders that take a 80 x 133mm sheet.
Festool Granat abrasives feature a high tech coating, providing maximum resistance to clogging and smearing. Long lasting, it produces a smooth, even surface finish. The abrasive is a mixture of hardened aluminium oxide and ceramic grits. The grit range covers aggressive stock removal to superfine finish sanding.
Engineered and manufactured to strict FEPA standards, Festool Granat abrasive guarantees a uniform abrasive coating for consistent sanding results. It is particularly effective on scratch resistant coatings, hard surface paints and high VOC coatings. This advanced abrasive reduces rework and ultimately saves you money by reducing costs and achieving a consistent, high quality finish.
Granat abrasive is suitable for use on paints, VOC clear coats, lacquers, plastics, mineral materials, acrylic, repair compounds, epoxy filler and similar materials. Also fits models RTSC 400, RS 400, RS 4 and LS 130
Manufacturer Part Number 497129
Pack Quantity 10
Abrasive Grit 180
Web Attribute Set Abrasive Sheets
EAN Barcode 4014549138489
