Our aluminium sash clamps have been fully tested and proved in our own workshop. They are lightweight, easy to manoeuvre and available in capacities up to 1,500mm. Ideal for lighter projects, they can be used alone or with Axminster Professional Sash Clamps for heavier tasks.
The heads and tail slides are cast aluminium, powder coated and feature good sized faces 50mm deep and 45mm wide.
The bars are a heavy gauge aluminium extrusion measuring 35mm x 22mm. Cast aluminium feet provide stability and prevent tipping, adding height for easy handle winding. Fully adjustable, they lock in 25mm increments. The threaded spindles are 12mm diameter with an Acme thread to allow for maximum force to be applied.
Available in clamping capacities of 600mm, 900mm, 1,200mm and 1,500mm sizes.
Maximum clamping pressure is 400kg.
Clamping Capacity 600 mm
Web Attribute Set Sash Clamps
EAN Barcode 5052511136452
