The Sandflex blade is virtually unbreakable and combines high cutting power with the exceptional wear resistance of M2 high-speed steel. The blades have a degree of flexibility, which is vastly superior to that of ordinary edge hardened or conventional flexible blades. They are suitable for all types of metal sawing, and the preferred choice in our own engineering workshops.
Bahco
Bahco Sandflex H.S.S. Hacksaws Blades
| Tooth Pitch \ tpi | 1.40 mm \ 18 tpi |
| Web Attribute Set | Hacksaw Frames & Blades |
| EAN Barcode | 7311518233570 |
