These specially designed blades cut thick hardwoods with ease. They will cut through beech or oak like a miniature bandsaw. They have a thickness range from 20mm to 75mm (with only light turns). They perform well, leaving a good finish requiring only a little sanding.
Recommended for use in hardwoods, medium hardwoods, Corian and plastic and plywood. Packs of 12 plain ended scroll saw blades.
For more information on each blade please see 'Information Downloads' below.
Additional Accessories No
Scroll Saw Blade Length 130 mm
Size & tpi 11 - 9.0 tpi
Size & Ref Number (11) - 90.611
Web Attribute Set Scroll Saw Blades
EAN Barcode 5052511114160
