The ForgeFix ForgeFast 31 Piece Impact Bit Set contains a mix of Pozi and Torx drive screwdriver bits and impact bit holder in a strong storage case. Engineered for durability and high-performance fastening in demanding applications. Manufactured from specially hardened steel, these bits offer extended wear resistance and long service life.
Designed with an integrated shock-absorbing torsion zone, they are ideal for use with impact drivers and other high-torque tools. The precision-machined tips ensure a secure fit, reducing cam-out and minimising damage to screw heads.
Supplied in a robust carry case for easy storage and transport.
Impact Magnetic Bit Holder with a 1/4in Hex shank. It is made from specially engineered hardened steel that provides a long working life. Fitted with an ultra-strong magnet for a secure hold.
Contents:
Pozidriv Compatible Bits (25mm):
PZ1 ×2
PZ2 ×5
PZ3 ×2
TORX® Compatible Bits (25mm):
TX10 ×1
TX15 ×2
TX20 ×5
TX25 ×5
TX27 ×1
TX30 ×5
TX40 ×2
Accessories:
1 × 60mm Bit Holder
Finish:
Black Phosphate
Web Attribute Set Screwdriver Bits
EAN Barcode 5028485219583
