The large diameter Soft Grip handle gives you great grip to apply the torque needed for driving in woodscrews whilst it also reduces fatigue. The smooth domed end offers the ability for a fast spinning action. A CrV bar allows for high torque usage reducing the chance of tip breakage, and being moulded directly to the handle creates a virtually unbreakable bond. Colour coded ends make it easy to identify the correct screwdriver for each screw type.
The 12 piece set contains:
Parallel
2.5 mm x 50 mm
4.0 mm x 100 mm
5.5 mm x 150 mm
6.5 mm x 30 mm (stubby)
Flared
5.5 mm x 100 mm
8.0 mm x 150 mm
Phillips
PH.0 x 75 mm
PH.1 x 100 mm
PH.2 x 125 mm
Pozidriv
PZ.0 x 75 mm
PZ.1 x 100 mm
PZ.2 x 125 mm
