Stanley
Stanley FatMax® VDE Insulated Screwdriver Set, 6 Piece
SKU: 112826
€34,00
The Stanley FatMax® VDE Insulated Screwdrivers which have a VDE insulated screwdriver tip that is individually tested to 10,000 volts and guaranteed to 1,000 volts. The soft-grip handle gives the perfect combination of great grip plus reduced fatigue and its large diameter offers greater torque needed for driving wood screws. The handle is moulded directly to the bar giving a virtually unbreakable bond. A heavy-duty plastic sheath running the length of the bar protects the user from live current. Contents: 3 x Parallel: 2.5 x 50mm, 3.5 x 75mm, 5.5 x 150mm. 2 x Pozidriv: PZ1 x100mm, PZ2 x 125mm.1 x Voltage Tester.
Manufacturer Part Number 0-65-443
Web Attribute Set Electricians Screwdrivers
EAN Barcode 3253560654436
