A plastic handle with a moulded rubber insert. Held at 45 the smoother is drawn slowly along the bead of sealant with the minimum of pressure leaving behind a professional looking, even finish. Excess sealant simply peels off the tool once dry. Apparently, fingers being licked before being used to smooth the bead are sometimes the cause of black mould appearing on the surface of sealant!
Web Attribute Set Tiling Tools
EAN Barcode 7015804600830
