Packed in a high quality storage case with an opaque lid and foam insert, the TNT-808 is a comprehensive woodturner's sharpening jig set.
The TNT-808 innovative Tormek tool set for woodturners contains everything you need to shape and sharpen all turning tools. The jigs give you complete control over the sharpening process. The jigs ensure you are able to reproduce and repeat your preferred bevel angles and tip profiles time after time.
The Tormek TNT-808 set includes the following Tormek jigs and accessories: SVD-186 Universal Gouge Jig, SVS-50 Multi-Jig, SVD-110 Torlock Tool Rest, TTS-100 Angle and Setting Gauge, LA-120 Honing Wheel, MH-380 Protective Cover and tuition manual.
The set is compatible with Tormek T-7, T-3, T-4 and T-8.
For more tips on sharpening please see Tormeks YouTube channel.
Web Attribute Set Grinding Jigs
EAN Barcode 7392485007104
