Over time, the diamond tip in your TT-50 Truing Tool may wear down or become damaged. Fortunately, it can be easily replaced! Simply use the ADV-D Diamond Exchange Tip for TT-50 to swap out your old diamond tip, restoring your truing tool to its original efficiency.
Pro tip: Before replacing the worn tip, try twisting it slightly. This might expose new diamonds, making the tip effective again.
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 7392485001072
